k_che
Create an oval column that gets bigger towards the top
Is it possible to create a column that is oval in the plan and then becomes larger and shifted at the end, as shown in the picture?
Of course I can create an oval profile, but shifting and enlarging it towards the top is something I could not solve.
Thanks in advance
Operating system used: Mac Apple Silicon Sonoma
2 Solutions
CosminF
I would:
1. Define a complex profile (a "base" oval) for your column.
2. Be sure to add stretch modifiers to it. Further info.
3. Be sure that the origin point of the complex profile coincides with the "axis" that you will use for the column
4. Place a column with your new complex profile. Go to the segments tab, and you can edit the top modifiers and the bottom. this will stretch the oval at the top and at the bottom.
hope this helps.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
Stefan L_
Plus this one:
Stefan - AC ...-29GER, WIN11
Go to post
3 Replies 3
CosminF
I would:
hope this helps.
Stefan L_
Plus this one:
k_che
Thanks! It works!
