2013-05-28 04:10 AM - last edited on 2023-05-24 12:47 PM by Rubia Torres
2013-05-28 07:50 PM
2013-05-28 10:36 PM
Matthew wrote:
For the level of detail you seek there are no really easy options.
You could take a look at Architile from Cigraph. I haven't had the need to try it but the other add ons of theirs have worked well for me.
Another approach would be to use profiled walls. These can only provide the horizontal grout joints though so you would have to use SEOs or profiled columns (at he right intersection priority) for the verticals, and this is only practical if the pattern is stacked square or rectangular tiles (no offset or stagger). SEOs and wall/column intersections can also cause performance issues if you are not careful.
If you do try the column approach be sure to set the tile layers to a different intersection priority from the rest of the building.
2013-05-29 07:17 PM
Jonathan wrote:
Thanks Matthew!
I'm doing the individule tile and multiply horz. and vert thing in just a few
locations. Where the tile is over a window or other opening SEO ops work great, but WOW, wouldn't want to do the whole house.
I'm doing this all on a diff. story.
Thanks for the info.
I will see if I can figure out how to attach a jpg when I can find some time.
It's alot of work but it looks great!
Best,
2013-05-30 02:11 PM
Jonathan wrote:Check to see if they are there when you zoom in (although I would guess that a 1/16" space will get lost when printed at most conventional scales). Depending on the zoom factor, ArchiCAD can drop lines draw on screen (but are still there).
I am using a 1/16" grout space between the tiles which might have been a mistake because when I checked how it looks in elevation I'm loosing the verticals, UGH!!! anyway to adjust some setting somewhere to get them to read?
2013-05-31 06:04 PM
2013-06-02 08:44 AM
2013-06-02 02:49 PM
another Moderator
