Creating a Fill with polylines?
archigreen
I cannot create a fill with polyline.
So when a explode the polylines they do not convert into lines.
How can I create a fill with out having to re-draw with lines my own polyline pattern?
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
7 REPLIES 7
Hi, use the Linework consolidation Tool, and mark the option to convert polylines in primitives. This will convert your polylines in lines and arcs.
Edit > Reshape > Linework Consolidation.
PD: you're missing your AC version in your signature
archigreen
Nice Tip.
Thank you Arqrivas.
ArchiCAD 26
MacOS Monterey
64 GB
OK, so I tried this on my shape below.  It acted as if it did as asked but it is still not a shape if group is off it is individual elements and I cannot create a heavy solid line and a fill pattern.
It was originally created in autocad
Eric Milberger, Architect | Master Planner
The above line consolidation will result in just lines.
If you want a fill, you will have to magic wand a fill to follow the perimeter or flood the area.
i need to find a good video to teach the use of the wand.  so much to learn.
Like this?
https://www.youtube.com/watch?v=Ng8u9m4h5E4
Or maybe this this? - I have never watched this one.
https://www.youtube.com/watch?v=_ncgvQ7jBh0
You can keep the fill and from fill settings you can add fill outline and match its color and weight with the poly line came from auto.
AC 28 INT 3110/WIN 11
