‎2014-06-16 01:44 PM
‎2014-06-17 01:41 PM
laszlonagy wrote:I've tried that too, still nothing!
Is there any chance that your Grid Snap is turned ON in the Floor Plan Viewpoint? It is a Viewpoint-specific setting so it may not be turned on in the Section Viewpoint and what you want to do works, but it is tuned ON in the Floor Plan Viewpoint and it does not work there.
‎2014-06-17 02:01 PM
‎2014-06-17 02:04 PM
‎2014-06-17 05:15 PM
‎2014-06-17 06:17 PM
‎2014-06-17 07:09 PM
laszlonagy wrote:Sorry, I should have reworded it... It doesn't work in a new file either.
The Tool will not make a difference because all Tools that can create polygonal shapes use the same code parts within the program to do it. So if it doesn't work for Fills, it will probably not work for Slabs, Roof etc. either.
This just might be a quirk in your Project file since it works fine in a new file as you said.
I would not waster any more time with it, just do it the way you can and mover forward.
‎2014-06-17 07:14 PM
maccad wrote:Actually, I checked your file (I managed to download it), and that is not a oval, it is actually an ellipse.
I don't have any snaps on, or any trace references... It works in Elevations, but on any plans (stories) it doesn't work, very strange!
