Creating lead roof folds
Hi, how can I create this sort of geometry on a lead roof in archicad?
http://www.celticleadwork.co.uk/images/lead-barrel274p.jpg
I know I could do it with a texture in artlantis afterwards but ideally I need to be able to view the ridge spacings etc. as I design so actual geometry for each of the 'folds' or 'ridges' would be better. I cant find a way to do it.
Thanks for your help.
4 Replies 4
My first thought would be to model it with a profiled wall and then save that as a library part. Changes would require revising the original profile and resaving the part but it's not too bad unless you have many instances.
This will be quite easy to do with OBJECTiVE. Refer to proposed answer to a similar question here.
Ralph Wessel BArch
Central Innovation
David Maudlin
Another option is the Shell Tool, Revolved with Detailed Construction options, just need to draw the profile. Create one segment then Multiply for the length of the roof.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks guys, I've had a play with Objective, shall try the shell tool too and let you know how I get on, that shell looks nice though. I need to do a similar thing for walls too since they're also clad with lead in my design. Here's a render to show what I mean (have just used a texture)
Apologies the image I showed at the start is a barrel, my roof is straight.
So i suppose I can use shell>extrude
