2011-01-06 09:49 PM - last edited on 2023-05-23 04:46 PM by Rubia Torres
2011-01-06 10:01 PM
2011-01-07 06:44 PM
2011-01-08 12:00 AM
raikopalm wrote:Also, ask your ArchiCAD reseller/distributor about the Modular Joinery object - it will enable this to be done as part of the window (see attached image). You should be able to get the object free of charge.
how could I make such wall fragment as shown in attachment.
2011-01-08 02:58 PM
2011-01-08 07:06 PM
another Moderator
2011-01-08 08:30 PM
2011-01-08 08:55 PM
2011-01-17 03:42 PM
Dwight wrote:I solved this problem like suggested above, but now my floor plan shows empty windows in these places. How can I make AC show complex profile walls on floor plans in these caps instead of empty windows?
For the problem you illustrate, I'd place empty window openings next to the windows in the main, thicker wall where the recessed quoin is to appear.
Then I'd fill the resulting gap with a complex profile wall showing the mortar joints.
2011-01-17 10:07 PM
