ā2018-06-18
03:51 PM
ā2023-05-24
08:21 AM
Rubia Torres
ā2018-06-18 06:30 PM
ā2018-06-19 07:57 AM
ā2018-06-19 09:32 AM
ā2018-06-19 10:38 AM
Mats_Knutsson wrote:You can't just cut a hole but can't you add a frame around where you want the hole and then delete the frames and panels inside that area?
I often use CW as ceiling but if there is a hole inside the ceiling it has not been doable before. I doubt 22 is any different.
ā2018-06-19 11:49 AM
ā2018-06-19 12:01 PM
mikas wrote:Those commands were only removed from the default WE menu. But could/can be added back via the WE - in AC21 and AC22. They were removed due to the new edit mode for CW in Section/Plan in AC21.
That seems to be the only way now. I can't find that command in AC21 enymore ("Subtract Fill from Boundary") nor it's relative commands (Redefine, Add..). They are in there with AC20, but not with 21. Anyone with the latest AC22, is it in there again maybe?
Well, they have a lot of new features in AC22 with curtain walls, so lets see..
ā2018-06-19 12:17 PM
