Gisele
Curtain Wall - Built in CW Door
Attached is a screenshot of the Curtain walls with built in doors. I have edited the settings to CW Door A: I changed the frame width, added handles, and changed a few materials...  I tried injecting the properties of CW Door A into CW Door B, vainly. I also tried to save CW Door A as a favorite to reuse it, vainly. What would be the best approach to add CW Door A to newly added curtain walls?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
1 Solution
julienK
the behaviour of the favourite palette is different  if you click apply  or double click on a favorite.
In edit mode  select a the panel you want to apply the door favorite to.
After opening the favorite palette and select your door:
- if you click apply  it only applies the type  of panel,  ie: single door, double door etc.
- if you double click on your favorite it applies all the attributes.
Go to post
julienK
