filhalbate
Curtain Wall Door issues
Guys help me in determining why this happened. When I insert a CW Door into a curtain wall, the entire material is glass. I've already checked and attempted to change its surfaces, but it still appears the same.
cuba
Probably used override surfaces under model attributes of the door in the curtainwall settings?
Apple M1 Max 32 GB
Latest AC
David Maudlin
filhalbate:
To illustrate Cuba's point, make sure this is not checked.
If the panel is not visible in your dialog box, then see this similar tip for showing it: Easily control the material of Door surfaces.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
