Curtain Wall Panel Element ID
For enlarged elevations, we tag each curtain wall panel with type. I'm using the new panel classes in Archicad 22 to create all of my panel types, set the element ID in the panel types to be consistent with our legend, then I label them on the elevation quickly.
The issue is that the element IDs keep changing for seemingly no reason? I copy curtain wall panels around to preserve the scheme/panel system, but each time I do that, it changes all of the id's in the panel settings.
For example, I set up a panel in the curtain wall setting with an Element ID "GL1c", meaning every time I use that panel class, I want the panel to have that ID. If I copy the curtain wall, and open the settings on the new curtain wall, the panel id under settings may have a) stayed the same, b) changed the number randomly to something like "GL8c", or c) defaulted to the standard Element ID for curtain wall panels.
I checked to make sure that "Assign new Element ID's" is turned off in my work environment.
Any ideas?
2 Replies 2
Aaron Bourgoin
We're doing the same here. Be sure to create Favourites of all your panel and frame classes and assign the IDs there so that they "stick".
It took some time to make sure that alll the classes were declared and fovorited, but once that's done, it becomes pretty easy to enjoy using the tool.
At long last.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Also, make sure that in the "Edit>Element Settings>Element Transfer Settings" Dialog, "ID" is checked to be transferred for Curtain Walls. Otherwise, if you are ALT-click one Panel, then CTRL-ALT-click to another Panel to transfer Panel settings from one Panel to another will not transfer the ID.
