Curtain Wall tool in horizontal plane
Leire Bilbao
Hello! Is it possible to put a curtain wall tool completely horizontal?
I would use this tool for pergolas, ceilings and so many things if I could put it any way I wanted...
CosminF
This might explain how to do it: https://support.graphisoft.com/hc/en-us/articles/26249174533521-Creating-a-ceiling-with-interchangea...
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Ok, I managed to model it and it shows the pattern or grid but I can't show the ceiling with a fill and colour. No choices for how it shows in plan?
CosminF
You might want to go into your Model View Options and under Curtain Wall Options make it so that the CW panels are visible:
They should then show up in your floor plan.
Then you can make a graphic override and make them any color you want.
