2004-02-24 03:54 PM - last edited on 2023-05-23 05:29 PM by Rubia Torres
2004-02-24 07:47 PM
2004-02-25 12:34 PM
outpostarc wrote:I haven't looked at the curtain wall object, but the wood doors have a problem in the code of the doors themselves which makes the door panel (leaf) model solid if any solid element operations have been done to the wall they are in. Is this what you mean?
I'm getting some weird things happening with the curtain wall door object and some of the wooden interior doors not showing right in 3-d. Any suggestions.
2004-02-25 03:38 PM
Matthew wrote:I just sent a file off to tech support about this very thing, not knowing it was a known bug. I had it occuring in walls that had been SEO'd and with doors D1 81 and D2 81 but door D2 French 81 displayed properly in the same walls. Is this problem limited to certain doors? Is there a work around?
2004-02-25 07:05 PM
Ted wrote:The problem is in the SEOs; the bug is officially recognized and is being worked on.
2004-02-25 07:15 PM
