Curtain wall hole
Mario Sacco
Is there a way to create a real hole inside a curtain wall?
I'd like to have real boundary and real panel quantities, not boolean operation.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
10 REPLIES 10
alemanda
I don't have archicad in front of me.
I suppose you tried to create a hole like you do with a slabs and I suppose it didn't work.
So my first idea is to split the cw into two parts, and assign manually the profile typologies and panel types as per your needs.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
mikas
That's what I have found out too, alemanda. Splitting it in half will allow a hole. You can't make a hole inside the curtain wall boundaries, but you can subtract any fill shape stretching from outside of the boundaries. It's done in section view. (Please see attachments.)
It is not so neat you probably wanted, but I believe thats the only way without using SEO (Solid Element Operations, which is called Boolean Operations in some localizations, t.ex ITA and FIN, I can guess).
AC25, Rhino6/7+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RX6800XT/W10ProWS
mikas
Could not attach a second image to earlier post, so here it is.
Mario Sacco
Thank you.
But I have complex shape with many holes e complex holes with curves.
Take a look at the image attached.
Split in many CW is to much work. But for now is the only solution.
I want to benefit CW quantities options for frames, panel.
This is not only a single solution. I must replicate this problem hundred of times for my client.
alemanda
Mariosmic
If the picture shows your real situation the easiest solution is to delete the panel at each hole. At the end you will have one cw only. The holes are just missing panels. And that's it.
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Mario Sacco
This is an example about the shape I could have.
alemanda
If you don't have to edit the pattern many time of course you can use slabs and beams. Maybe is the quickest way. I would do this way.
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Ruben V
I agree with alemanda.
Use the CW-editor to adjust/delete profiles and remove exces panels.
More difficult with round shapes (as in the first pictures) - as CW 'transforms' these into (large) segments...
(òÓ,)_\,,/
www.studiov2.be
Archicad 26/27 + Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
Erwin Edel
Try working with Extract Boundary to Fill and redefine boundary from fill commands. In case of the sloping curtain wall, the holes would have to be ellipses in the fill.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
