Curtain wall / window ,different material frame for outside and inside
W_OZ
Hi, i'm a bit new to archicad, would it be possible to differentiate a frame of a caurtain wall or a window inside and outside? For example on the outside frame i would need black metal finishing, while on the inside frame just painted white.
thanks
CosminF
On a curtain wall you can override the frame body and the frame cap differently (of course, you need to select a frame type that is comprised of a frame AND cap). Select the curtain wall, go to its properties, frame and you have the options here:
Hope this helps
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
1 REPLY 1
CosminF
Hope this helps
