ā2004-05-27
02:11 AM
ā2023-05-25
06:23 PM
Rubia Torres
ā2004-05-27 08:11 AM
jkipfer wrote:The curtain wall object doesn't cut a hole, it is designed to go in a gap between walls. Try using two windows instead.
What I want is a large window opening, divided horizontally into two. The top and bottom will both have vertical mullions, but they aren't meant to line up with each other.
I've tried doing this with a curtain wall but the curtain wall doesn't cut a hole in my wall. Also, I can't stagger the mullions of the upper and lower sections. So I cut a hole in my wall and used two separate curtain walls to create both sections. I was hoping to group all this and be able to copy it to be.
ā2004-05-27 03:25 PM
ā2004-05-27 10:21 PM
jkipfer wrote:Jason,
Using window presents a different problem. I can get the window divided into two using a transom and further divide these two areas by changing the number of panes in the sash frame attributes, but what if you don't want these spaces to be equally divided?
ā2004-05-28 03:47 PM
ā2004-05-28 08:10 PM
jkipfer wrote:You have to use two I suppose ...
That solves the problem of being able to cut a hole in the wall, but I still have the same problem with the mullion spacing. It can be set to whatever I want, but I can't have 7 divisions in the top half and 6 divisions in the bottom half. I'm trying out a door from objectsonline.
ā2004-05-31 07:19 PM
ā2004-05-31 08:35 PM
jkipfer wrote:But you can get them by Find&Select. Group - no, you can't - then create selection. Multiply the holes, or drag a multiple copy. Multiply the selection. Done.
Selecting in the plan view, I can't get all the objects at once.
ā2004-06-01 03:42 AM
jkipfer wrote:You can group them after a fashion. Make a section of wall that is entirely filled by the assembly of doors and windows. This wall can then be placed in empty holes in the main walls and moved and copied as an assembly.
You can't group window and door objects.
