Curved Beams
How can I create curved beams with variable radiuses?
4 Replies 4
Bruce
Beams can be curved in plan, same as walls. If you draw beams using the chain geometry method, there are a few options to draw your curves "on the fly." You can also edit these curves afterwards.
You can't curve a beam in the vertical axis (ie arch).
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Cadimage Objective can bend & twist beams
Erwin Edel
If it's all bending in one plane, you could try creating it with curved walls, convert to morph/save as object. Or try ye olde Truss Maker.
Or just use morph from the go, but I find making a morph follow a predefined path quite tedious. And if you want to change the path afterwards, it's near impossible.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Bill
There is an object called Web Beam Curved 19, in the US library, under 13 30 00 Special Structures... this object will let you arc the beam vertically (i.e. in elevation).
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
