2006-09-15 09:27 PM - last edited on 2023-05-23 05:13 PM by Rubia Torres
2006-09-18 04:06 PM
2006-09-18 04:34 PM
2006-09-18 08:25 PM
2006-09-18 08:48 PM
2006-09-18 09:45 PM
X-Calibur wrote:If you figure out the geometry first (lines and arcs in some auxiliary geometry layer) and then multiply-rotate-spread/increment either walls for the paint stripes, or whole parking space objects, or whatever idea you come up with, it shouldn't be that time-consuming to do it once.
I've taken the painstaking route of using one spot at a time and rotating each line but that takes waaaaaaaay to long...
2007-08-21 06:39 AM
jocontreras wrote:Parking Lot Maker now does wide lines in straight, angled, or radial
Have you tried parking lot maker 3.0. from objects on line? I
t is not perfect, but it has taken care of most of my parking problems. Its 40 dollars but the time it has saved me has already payed itself. The only problem with this library part is that it doesnt make double lines between parking spaces. You may need to thicken these lines in blow ups or in large scale drawings.
2007-08-21 11:50 AM
2007-08-22 12:46 AM
jocontreras wrote:Hi jocontreras
jocontreras wrote:
I ask if theres no special price for people who own parking lot marker 3 to do an upgrade to 4?
