Curved composite walls
davor_r
I have same composite for walls. When the wall is straight it shows fine in 3d. When the wall is curved it dissapears core of the wall. Does anybody knows how to solve the problem?
AC22 • iMac 3,4GHz Intel Core I5 | 16 gb ram • OSX10.14.4
4 REPLIES 4
I am not having this problem.
Does it matter how much you curve the wall (i.e. almost straight) or if the curve goes the other way?
Can you save a file with just those walls and upload it here?
davor_r
No Barry it doesn't matter if i have small or big radius of curve. But if I make it straight the core of walls shows up.
Here is the link when you can download my file with only walls.
link: https://we.tl/t-vRx6iuDtQ2
It is because you have zero thickness skins in the composite.
It seems that curved walls do not like this.
Give them even the smallest amount of thickness and the walls will be OK.
davor_r
Yes Barry. That was the problem. Solved now. Thank you a lot.
Davor
