2008-01-21
08:58 PM
2023-05-25
04:58 PM
Rubia Torres
2008-01-21 09:39 PM
2008-01-21 10:12 PM
KRAY345 wrote:If you mean to curve the whole staircase, no. You'll have to recreate the stair from scratch.
i have a curved wall in a project i am working on.
was wondering if anyone knows how to curve a straight set of stairs tothe wall
2008-01-21 10:39 PM
KRAY345 wrote:I'm also not sure what result you're seeking, but the attached image shows how this can be easily done with OBJECTiVE:
2008-01-21 11:54 PM
2008-01-22 05:06 PM
2008-01-23 02:16 PM
2008-01-25 10:51 PM
Ralph wrote:Would it be possible for you to write a little more in detail on this way of doing it, as it looks pretty easy. i have looked at the videos but fing it a little confusing.KRAY345 wrote:I'm also not sure what result you're seeking, but the attached image shows how this can be easily done with OBJECTiVE:
was wondering if anyone knows how to curve a straight set of stairs tothe wallYou can see more at: www.encina.co.uk/objective.html
- - Draw a section through the stair
- Create an elevation profile
- Bend it to the curve of the wall
2008-01-26 06:26 PM
2008-01-26 07:23 PM
KRAY345 wrote:OBJECTiVE currently makes 3 different profile types, which all have unique properties. Two of them, section profiles and elevation profiles, can be bent to a curve in 3D. I'm suggesting that you use an elevation profile for the stair. I've attached some images to show how this type of elevation is made, and how it can be bent.Ralph wrote:Would it be possible for you to write a little more in detail on this way of doing it, as it looks pretty easy.KRAY345 wrote:the attached image shows how this can be easily done with OBJECTiVE
i have a curved wall in a project i am working on. was wondering if anyone knows how to curve a straight set of stairs tothe wall
