Custom Composite Wall Intersections
Any input here would be welcomed!
I've created multiple custom composite wall types and cannot for the life of me get them to intersect correctly (see screenshot). I've tried making all the composite skins the same priority, the walls themselves are the same priority, I have the 'enable skin priorities' box checked, but still no luck... what am I missing?!
11 REPLIES 11
It looks like the lower wall is intersecting with a wall on a hidden layer.
Matthew -
Good thought, but unfortunately, I don't think this is the case. There aren't any other walls in this area, and the layer the visible walls are on has a distinct priority that is not shared w/ any other layers...
Check out Cecilia's post in THIS THREAD for an explanation and diagram of skin priorities. This should help.
Thanks s2art -
Cecilia's diagram was helpful and is basically how I understood skin priorities to work. I've attached a screenshot that shows how I have the priorities set up w/n my composites. The '8s' are finishes and the '4s' are cores, but it doesn't seem to want to intersect correctly. Could it because I Have different skin patterns to accommodate the 45 degree angle? I feel like I'm missing something pretty simple here!
You have the priorities reversed. The core should have the higher priority number.
Hi Matthew -
Just reversed the priorities so the core has a higher number priority, but the result is the same. Any other thoughts? Thanks.
Rod Jurich
Can you post a s/shot showing your reference line clearly.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
alemanda
Check the presence of some column in the intersection.
I noted that columns make interference with the composite structures if they are in a layer with the same number of intersection of the walls ... I think it is a bug
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Absolutely in order to get a correct "contextual" fill orientation linked to the wall's direction you must
1. use the same fill pattern (to get correct skin connections)
2. set the skin fill to be linked to element origin (to get correct orientation)
see attached
