Custom Curtain Wall Panels
Maybe it's an obvious question, but where does one find the option to load custom panel / frame profile / accessory in the Curtain Wall tool in version 22? I can not seem to be able to find it anywhere...
And while I'm at it, how does one do the same in version 20? There, I was a little more successful, there is the possibility to load a custom panel easy to find, but whenever I try to load one of the selected Curtain Wall Panel files which I just created, I get an error message that the file is not a Curtain Wall Panel file.
I’m not sure I’ve understood your request
I think you should try to go into your curtain wall (édit) and select the panel you want to modify
Then try to enter into the panel parameters
And finaly choose your custom panel
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Lingwisyer
Guru
I do not use the curtain wall tool, but I would have thought that the relevant parts would just need to be loaded in your library and if they had the right subtype, they would appear for the relevant tool. The object shown in your image, is it's subtype set to curtain wall panel?
Ling.
