Trimmed material not the same as facade material
Hello!
How do I get the same material on this section part of the wall, as it is on the facades?
I got this shape of the house by 'Trimming elements to roof' tool.
In both roof and walls properties I checked symbols for 'Override surfaces', and chose the stone material, but this linear part still stays different afterwards.
Thank you!
1 Solution
You must assign a material with a slightly higher priority for the roof to match the original surfaces
Otherwise you can constrain slices of walls and roofs with the desired surface
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Go to post
Christophe - FRANCE
Archicad 15 to 29
Thank you Cristophe!
It worked!
