Modify wall length question
Is there an easy way to modify the length of two opposite walls in a rectangle of walls that have been created using the "chain of walls" tool? I have been able to stretch of shrink a single straight wall by selecting it and clicking the end point. When I do that, I get the menu option shown in the first picture.
When I click the end point of a chain of walls, I no longer get the option to add or subtract from it. (See the second picture.)
Is there a way to shrink two sides of the rectangle of walls, leaving the other two sides as is?
1 Solution
Brett wrote:
Click on the face of the walls while all selected and then you will get the pet pallet you need.
Here is an image to help explain.
Go to post
3 Replies 3
Brett Brown
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
It worked! I had to suspend grouping to get the menu. Thank you much.
