ā2006-06-19 05:06 PM
ā2006-06-20 06:55 AM
TomWaltz wrote:Tom,
Anyone else seen a problem like this?
These are walls drawn with a custom profile. Each skin is set to a different priority and "Enable Skin Priorities" is turned on.
The plan looks correct.
Why do the corners not clean up properly?
(those are 3 different corner screen shots composited into 1 image)
ā2006-06-20 07:18 AM
TomWaltz wrote:ouch mate!
ā2006-06-20 04:40 PM
ā2006-06-20 04:58 PM
ā2006-06-20 05:26 PM
ā2006-06-20 05:46 PM
ā2006-06-20 05:51 PM
ā2006-06-20 07:34 PM
ā2006-06-20 11:58 PM
r wrote:...Not a mac issue. My complex walls clean up perfectly and windows/doors appear correctly. Each edge has a custom material setting. I modified a profile by moving the fills to locate the origin on the other side of the wall (since the origin determines the reference line), changed some custom edge settings, and turned off clean wall intersections; the walls still intersect cleanly in 3D & elevation.
Tom
...could this be only happening in mac....
