Custom Symbol fill
I tried making a custom symbol fill as instructed here: http://www.youtube.com/watch?v=QCsR3c2Em5E
It worked fine on a different file, however only the hotspots are showing up on this new file. Any idea what I am doing wrong??
13 Replies 13
@pbg wrote:
Any ideas as to why the hotspots are showing up though?
I don't know.
There was a post just a couple of weeks ago that brought this problem up as well.
The interesting thing is if you make a symbolic line type and use hotspots, they don't show and just act as a spacer.
pbg
Interesting, I will have to track that post down...
I just made a custom line out of the pattern I posted above (4 hot spots, 2 lines), and the hotspots show up there as dots... Maybe I am missing something?
Regardless, thank you so much!
AC 26/28 USA (latest build) - Windows 11 - Intel i7 - 64 GB Ram - NVIDIA RTX A4000
Here is the post ...
https://community.graphisoft.com/t5/Design-forum/Hotspots-visible-in-symbol-fill/m-p/340801
I might be mistaken about the hotspots in the lines.
I just looked at one for "Ridge Tile (side)" and that shows the hotspots in plan.
I could have sworn I had used hotspots in the past and not seen them.
pbg
Thanks for the link - must of missed that one when I started my search. I will check it out now.
You rock! Thank you so much. Truly appreciated.
