Custom box of some sort
Hi
I am rather new to modeling in ArchiCad and i have a problem. I have to model three boxes of some sort and put windows in them, but i don't know how to make custom shaped walls... Each side of the box has a different dimension, no lines are parallel and almost all sides are not perpendicular. I am adding a picture of my problem, hope anyone can help.
The wall surfaces appear to be planar. If this is true you can use sloping walls which should join properly in most cases. You may need to use some SEOs as well for the tops and any parts that won't join quite right.
If there are simple curves (circular or spherical) you can use a profiled wall.
If you have complex curves and have AC15 then the shell tool is probably best.
Maybe this kind of boxes?
Yes something like that . Tnx for your help, i know how to make it now
bei
