Mats_Knutsson
Mentor
Custom profile wall lost in 2D
I did a roof accessory as a custom profile (wall) and after fiddling with it in the section view (positioning it to the right position) it suddenly disappears in 2D plan view. It's there in 3D and 2D section as shown in fig. Que-pasa?
/Mats
AC 25 SWE Full
5 Replies 5
It happens to me too, with roof accesory.
Restart your programm, than you will see the disappeared objects.
Mats_Knutsson
Mentor
Unfortunately no... It's not an AC roof accessory...it's a custom profile wall...
/M
AC 25 SWE Full
It likely has to do with your floor plan display for that wall. Set this to Outline only and see if you can now see it on the plan. If you use the projected options and the wall is higher than your cut plan, the wall will "disappear". Projected with overhead will allow some control of what is above the cut plane. You can also adjust the cut plane if 2d representation is critical.
Mats_Knutsson
Mentor
Thanks, yes it's floor plan cut plane. Projected with overhead is the trick, shouldve known that... Meanwhile I stumbled on another thing which is harder to solve. But I need to wait till I'm sure it's not sbs.
AC 25 SWE Full
Of course that is new option for AC10!
