ā2006-06-28
11:12 AM
ā2023-05-23
03:29 PM
Rubia Torres
ā2006-06-28 11:47 AM
ā2006-06-28 12:01 PM
Archi wrote:Unfortunately no... It's not an AC roof accessory...it's a custom profile wall...
It happens to me too, with roof accesory.
Restart your programm, than you will see the disappeared objects.
ā2006-06-29 06:24 AM
ā2006-06-29 10:44 AM
Mike wrote:Thanks, yes it's floor plan cut plane. Projected with overhead is the trick, shouldve known that...
It likely has to do with your floor plan display for that wall. Set this to Outline only and see if you can now see it on the plan. If you use the projected options and the wall is higher than your cut plan, the wall will "disappear". Projected with overhead will allow some control of what is above the cut plane. You can also adjust the cut plane if 2d representation is critical.
ā2006-06-29 11:41 AM
