Denissss
Custom windows (half triangle)
Hey,
Is this type of window creatable only by making a custom window or it can be created with existing library ones?
It is not a difficult shape, but seems there is no option in the existing library? I tried to make it from one square and one triangular window, but it turned out bad especially if I needed to use casing.
Archicad 28 Solo, Windows 11 Pro, Dell Precision 7560 Laptop (64GB RAM, i7-11850H, RTX A4000), Dual 27-inch Dell Monitors (2560x1440).
3 Replies 3
 Did you use the ganging checkboxes when you tried to combine the rectangle and triangle?  ... it's purpose is to combine the frames and casing of adjacent windows/doors.
Denissss
No, I did not try it.
I did not actually combine them. I just put them next to each other hoping I could do something like that, but it just came out wrong and ugly. I did not know about ganging options yet.
Will try it out when I get back to that project.
Thanks!
Steve Jepson
If all else fails, get as close as you can using the windows in the library, then convert them into a morph, adjust the morph as needed, and save them as a new window object.
