Ronarc
Customize wall int/ext
Hi I m new to AC and this forum so please bear with me… I want to draw an internal wall 250mm thick. I’m trying to copy the preloaded generic 110mm wall but can’t figure out how to create a new generic internal wall that’s 250mm from the 110mm template or from scratch.
Similarly I want to use a 250mm generic wall for the external walls so I would copy the parameters of the internal wall to make an external wall out of it. Any help is much appreciated, thank you 🙏
EDIT
I found Composites Edit tool, I think that solves my problem
1 Reply 1
Yes, the composite editor is where you can create new (or duplicate) composite walls (can be a single skin or multiple skins).
If you just need a single skin wall you can use the 'Basic' geometry method rather than a composite.
I prefer to use composites, even for single skin walls.
Barry
