Eric Milberger
Cut and paste des not work in 29
Can no longer cut and paste in 29I have a model in a 29 version and want tp paste the items into another 29 model and it does not work
Operating system used: Mac Intel-based
Eric Milberger, Architect | Master Planner
2 Replies 2
marcoariveross
It works well.
But you need to be careful about which design options you're using. The same applies to rehabilitation options; if you create rehabilitation phases but they aren't included in the file where the copied data is pasted, it won't appear.
You should verify the following:
1. Both files have the same design options.
2. Both files have the same combinations of design options with their respective sets of design options.
The file that receives the copy won't be created automatically, which is why it might seem like it's not copying.
Try that first.
BIM Manager Pavimaq
Lima-Perú
Archicad 29-Windows 11-64Gb RAM
Patrick M
design options and renovation filter can both impeded the paste...
also, just to make sure you are checking all the boxes; copy/paste from floor plan only.
if all that fails, select what you need from file A, go to file > external content > save selection as module. In file B, drag/drop that module into the view you need it in (in floor plan for model elements)
