Cutting on a round wall
Greetings to all Users
I have a problem, regarding modelling - I am not able (I don't know how to do it) to cut wall irregular (need to model it like it is for reconstruction purpouse).
I would apprieciate any help with this topic 😉
3 Replies 3
David Maudlin
ARGAS:
You should look at Solid Element Operations (in the Help files see: Elements of the Virtual Building > Solid Element Operations). To use this you will need to create some elements that are the size and location of the parts of the Wall to be removed (could be other Walls, Slabs, Morphs, etc.), then use these elements to remove part of the target Wall. The operator elements can then be put on a hidden layer, but not deleted.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
ARGAS:
David
Thank you David, that should do the work. Will show effects afterwards.
Karol
David Maudlin
Karol:
Yes, please post an image when done. Thanks for adding the signature.
David
