2016-07-19 08:47 PM - last edited on 2023-05-24 08:38 AM by Rubia Torres
2016-07-20 03:02 PM
2016-07-21 04:39 PM
David wrote:Thank you David, that should do the work. Will show effects afterwards.
ARGAS:
You should look at Solid Element Operations (in the Help files see: Elements of the Virtual Building > Solid Element Operations). To use this you will need to create some elements that are the size and location of the parts of the Wall to be removed (could be other Walls, Slabs, Morphs, etc.), then use these elements to remove part of the target Wall. The operator elements can then be put on a hidden layer, but not deleted.
2016-07-22 01:50 PM
