DISTRIBUTE ALONG CIRCLE
Not had to do this before, so may be basic question.
Tried all the things I could think of but so far no go.
What I want to do is array/distribute square objects (in this case columns) along the circle path to the divisions I have set up, in this case 12, (although they don't show in this screen capture).
I also want them to maintain the orientation to the center of circle.
Is this possible without having to set each one individually?
thanks
lec
3 Replies 3
Dwight
You can do it with objects in AC13, but not columns, yet.
But, it isn't so bad using the divisions trick.
Set divisions to 12 to get gravity nodes - placing is fairly quick.
Dwight Atkinson
Dwight
Duh - read it wrong.
Just use multiply, rotate.
See this for details.
Dwight Atkinson
Dwight
But you only need 11 copies, not 12.
Dwight Atkinson
