β2024-12-04 01:08 PM - edited β2024-12-04 01:28 PM
Dear All,
Let me introduce Dandelion to you, a revolutionized point-cloud-based modeler for Archicad!
Dandelion is a powerful yet lightweight point-cloud-processing application designed specifically for Building Information Modeling (BIM) software. With Dandelion, you can efficiently work with point cloud data, streamline your BIM workflows, and enhance your project accuracy.
Please feel free to download and try it, it has a free version: https://bimwings.com/product/dandelion-free/
You can check the teaser video on Youtube: https://www.youtube.com/watch?v=0ysL14fhadE&t=2s , and all the related videos here: https://www.youtube.com/@BIMwings .
Currently we are working on the one click native Archicad stair creation: https://www.youtube.com/watch?v=3jYY0t1IIkk
Any feedbacks and idea are very welcome: info@bimwings.com
Best,
JΓ³zsef L. Kiss
BIMwings
β2024-12-04 02:52 PM
π€― OMG! That looks incredible.
Very keen to try this out!
β2024-12-04 09:43 PM
No macOS-Version?
β2024-12-05 07:26 AM
@torben_wadlinger Thanks for the reply! No macOS version at the moment, however we will release it as soon as we see the demand.
β2024-12-05 09:53 AM
looks very promising! thank you!!
I tried to import large point clouds and smaller point clouds - is there some documentation about the tool or the maximum cloud size?
β2024-12-05 04:15 PM - edited β2024-12-05 04:17 PM
Dear @_nique_ !
Thanks for the feedback!
For geometric transformations, visibility options, and the current three main user modes (planar subset detection and geometry creation, segmentation box, and measurement of rectangular openings), Dandelion has a built-in help, available in the Help/Show detailed help with shortcuts menu or by pressing ?.
We have also provided a number of tutorial YouTube videos including:
Maximum cloud size:
Aside from the number of CPU threads and the size of RAM, the size of the point cloud that can be loaded, rendered and interactively processed in a meaningful amount of time, depends primarily on the video card's memory (VRAM) size and other capabilities of the GPU (since RAM size usually is much bigger than VRAM size, usually this represents the bottleneck).
It is recommended that users avoid trying to load a point cloud with a byte size larger than that of VRAM. Due to some technical reasons, currently Dandelion assumes that the available VRAM in GB must be approximately greater than the number of points multiplied by 28 / 1024^3, e.g., if someone is trying to load 100 million (i.e. 10^8) points, then at least 10^8 Γ 28 / 1024^3 β 2.61 GB of free VRAM is needed by Dandelion.
Anyway, the huge file size handling is on our roadmap, we are working on two scenarios parallel:
If you need any more help, please let us know!
Thanks!
β2024-12-05 05:25 PM
I see. Would not be a unified ram system better, like Apples and Qualcoms ARM-Architecture? As far as I understand you let the graphics card do the heavy lifting (which is smart).
β2024-12-05 06:57 PM
Hi.
I encountered two problems.
1. When installing It didn't automatically recognise the location of the Archciad. so I did it manually
2. When starting the addon it gives me an error cant start Dandellion viewer.
Can you point me out how to fix the issue?
Stefan
β2024-12-06 10:42 PM - edited β2024-12-06 11:20 PM
Hi Stefan,
Thanks for the fantastic discussion today! This issue was related to the installer, and has already been fixed.
If anybody faced this issue, please delete the manually copied APX files if there are any, and use the updated installer (you should purchase Dandelion again for free from the store).
Best regards,
JΓ³zsef
β2024-12-07 12:59 AM
Congratulations, looks like a great plugin, and much needed. Please consider the release of the Mac version, a lot of us are on Mac, and it is one of the important reasons why we choose to work with Archicad. Keep up the great work!
