2006-10-06 05:18 AM
2006-10-06 06:07 AM
2006-10-06 07:41 AM
archislave wrote:Using poly lines have this result.
The fact that dashed lines do not cross /................had draft the lines.
I just can't understand such an oversight after 20 years of Archicad(':evil:')
2006-10-06 03:51 PM
2006-10-06 04:33 PM
archislave wrote:Yep.
Have I discovered another much requested feature over the years? .
2006-10-06 05:07 PM
2006-10-06 05:16 PM
2006-10-06 05:30 PM
archislave wrote:Some people follow the same credo that a good drug dealer never uses his own product.
So ... to what do you attribute such neglect for 20 years - Is it really difficult to program or they don't care or deem it important? I doubt it can be that hard since Autocad has had it since the beginning. I wonder if Revit does this properly?
Does it do any good to keep posting this as a wish list item?
2006-10-06 07:56 PM
Geoff wrote:Tip:
Add to this the fact that it's almost impossible to get the dashed outlines of two polyline based objects to align. So if you want to use dashed lines for your multifaceted roof, the common lines where the roof planes meet appear as solid. Once again the Virtual Building ideal is defeated by a small oversight that forces users to draft over their model
2006-10-06 08:10 PM
archislave wrote:Hey, I like clean line intersections as well as the next guy, but sheesh! This sounds like a really tightly wound spring.
The fact that dashed lines do not cross at their endpoints is perplexing since Autocad has always done this. I am working with an Architect on a project who will not tollerate it.
