archislave
Dashed lines not solid at end - What' up with that?
The fact that dashed lines do not cross at their endpoints is perplexing since Autocad has always done this. I am working with an Architect on a project who will not tollerate it. I don't like it either and might be forced to somehow had draft the lines.
I just can't understand such an oversight after 20 years of Archicad(':evil:')
Archislave
archicad 26.0 US, M2 Macbook Air
10 Replies 10
Check the linetype settings. In the attached image, it appears that if the first dash setting is 0 the line starts with a dot. All other linetypes in that image have a positive integer as the first dash figure, and all start and end with solid sections.
Rod Jurich
archislave wrote:
The fact that dashed lines do not cross /................had draft the lines.
Using poly lines have this result.
If you use grouped lines then they close.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
archislave
Thanks for the feedback, guys. I see that there are workarounds, however it does not help when showing a slab footing - unless there is yet another workaround.
Have I discovered another much requested feature over the years? It is like the cell phone has developed into a video camera but voice quality has been forgotten - it still is primarily a phone - but they forgot it's original purpose.
I find that to work in archicad I have to stop every 15 minutes and ask a question taking the time to write it out on email or the forum. It really knocks down productivity.
Archislave
TomWaltz
archislave wrote:
Have I discovered another much requested feature over the years? .
Yep.
Tom Waltz
SeaGeoff
Ace
Add to this the fact that it's almost impossible to get the dashed outlines of two polyline based objects to align. So if you want to use dashed lines for your multifaceted roof, the common lines where the roof planes meet appear as solid. Once again the Virtual Building ideal is defeated by a small oversight that forces users to draft over their model
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
archislave
So ... to what do you attribute such neglect for 20 years - Is it really difficult to program or they don't care or deem it important? I doubt it can be that hard since Autocad has had it since the beginning. I wonder if Revit does this properly?
Does it do any good to keep posting this as a wish list item?
Archislave
TomWaltz
Some people follow the same credo that a good drug dealer never uses his own product.
Tom Waltz
Tip: http://archicad-talk.graphisoft.com/viewtopic.php?t=9936
Richard
AC26 (since AC6.0), Win10
Hey, I like clean line intersections as well as the next guy, but sheesh! This sounds like a really tightly wound spring.
Richard
