Define the auto connection of wall freely
I make the wall-like skirting on the wall. However the skirting automatically connects with the wall. So the plan display of the skirting is improper. Are there any ideas to solve this?
4 REPLIES 4
Change the intersection priority of the skirting skin (if composite or profile wall) or element relative to the other wall.
http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/common/html/wwhelp.htm#c...
AC 29 USA and earlier   •   hardware key   •   macOS Sequoia 15.7.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Change the cut fill of the skirting wall.
alemanda
or put the skirting onto a layer with a different number in that combination of layers. In this way you can switch off for clearer plan visualization.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
