Define the auto connection of wall freely
I make the wall-like skirting on the wall. However the skirting automatically connects with the wall. So the plan display of the skirting is improper. Are there any ideas to solve this?
4 REPLIES 4
Change the intersection priority of the skirting skin (if composite or profile wall) or element relative to the other wall.
http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/common/html/wwhelp.htm#c...
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.9, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Change the cut fill of the skirting wall.
alemanda
or put the skirting onto a layer with a different number in that combination of layers. In this way you can switch off for clearer plan visualization.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
