Define the auto connection of wall freely
I make the wall-like skirting on the wall. However the skirting automatically connects with the wall. So the plan display of the skirting is improper. Are there any ideas to solve this?
4 Replies 4
Change the intersection priority of the skirting skin (if composite or profile wall) or element relative to the other wall.
http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/common/html/wwhelp.htm#c...
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Change the cut fill of the skirting wall.
alemanda
or put the skirting onto a layer with a different number in that combination of layers. In this way you can switch off for clearer plan visualization.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
