2006-05-17
03:54 PM
2023-05-25
06:00 PM
Rubia Torres
2006-05-17 04:11 PM
habiatuq wrote:Not exactly. You can 'incrementally' magic wand regions by using the polygon palette's Add button. (Select zone, click on edge/corner, choose Add, magic wand the other Zone.) If the zones are touching, this should just work. If they have walls between them, you'll need to add the 'connections' manually.
He all, I was wondering if there is a quite way to create single slab for a number of adjacent zones by means other than tracing these zones. I have tried to use the magic wand, but It seems to want to create a single slab element for each individual zone.
2006-05-17 10:35 PM
2006-05-18 02:30 AM
2006-05-18 03:18 AM
2006-05-18 04:28 AM
2006-05-18 06:16 AM
2006-05-18 07:03 AM
habiatuq wrote:It's possible that it's not detecting the zone boundaries (I haven't tried it myself) but that would be strange since it works with most everything else. I'll test it in a bit when I get the chance.
Matthew this is a great method. However, I am not able to make it work for me. not sure what I am missing.
I'll keep trying.
thanks again
2006-05-18 05:01 PM
2006-05-18 08:30 PM
habiatuq wrote:Sadly it seems that zones are not detected by the magic wand process. I just tried it myself with only zones and an outline fill. If I select only the fill and try to subtract the empty space, the entire fill is deleted. If the zones are also selected it does nothing at all.
Hi Matthew. I tried you "Shrink Wrap" method with a number of polygons created with the Fill tool. It seems to work just fine. but I am still unable to make it work for Zones.
any ideas why?
