‎2006-05-11 05:00 AM
‎2006-05-13 08:28 PM
‎2006-05-15 03:48 PM
‎2006-05-16 11:19 PM
‎2006-05-17 05:13 AM
Sarah wrote:You need to explain in a little more detail what you are doing. Are you in plotmaker or Archicad. The view name is not related to the detail marker #, and it is unclear you are referring to a the detail marker #. Are these auto linked details? If so the markers are only filled in in plotmaker.
Hi Mike
Thanks for your advice. Even though I change the detail's name in views- it does not change the number on the detail marker, and although the drawing which the marker is linked to has changed the detail does not update.
‎2006-05-17 07:11 AM
Sarah wrote:The ID number for the marker is set in the project map or settings dialog/info box. The sheet and drawing numbers are usually placed automatically in PlotMaker. The names in the views are typically used by the drawing title in PlotMaker. Remember that one source in the project map can be used to create as many views as you like, and thus the dichotomy.
Hi Mike
‎2007-03-21 06:17 PM
‎2007-03-23 06:59 PM
‎2007-03-28 10:34 AM
Djordje wrote:I've spoked about autotext ability of PM. I want to understand, how can plotmaker know - what detail is correspond to its marker. And how to control this mechanism by hands.
Put the Archicad version and build and the OS that you use in your signature
