Difference from 18 to 19
After the update for 19 I have finally loaded & started using it.
But have noticed that when I place a line or wall, then select to stretch the line or wall, the stretch command in the pet pallette is not available, I only get the Drag/move, rotate, mirror & multiple copy.
Then if I deselect the line/wall & then re-select, the stretch command is available.
This does not happen all the time.
Is there some setting in 19 that is causing this?
12 Replies 12
I would try to update the graphics card driver just to make sure that is not the source. I have seen such strange display behaviour caused by graphics card drivers in the past.
Thanks will do.
DGSketcher
Legend
There seems to be a pattern growing here on the forum of the new guidelines and snaps causing unwanted behaviour...
