Different scales, different fills
Hi, I am using archicad 11. I have a quick question (I hope) on using fills. I'd like to use different fills for slabs, depending on the scale I'm printing. So, solid fill for 1:500 and for instance structural concrete for 1:20. Is this possible without having to manually adjust the fills each time?
Thanks for your help.
Kindest,
Peter de Ruijter
Amsterdam (NL)
4 REPLIES 4
This cannot be set for the Slab.
What you may try is Model View Options. You can set Solid for the various Fill Categories there. I don't know whether you are talking about Slab Cover Fills or the fills of the Slab in sections (Cut Fills).
There are options for both in the Model View Options Dialog.
One problem is that it sets the fill for all fills in all elements, not only Slabs.
See if that works for you.
That's exactly what I needed...
Thanks laszlonagy
See, I can read you mind.
YOU did not even ask and I gave you the answer.
hahaha it's like magic hahah
I hope you continue doing this a lot hahaha
