Dimension stuck at odd angle to walls
I know there's a simple setting, but where?
I click to set points then double click to get dimension line, ...but the dimension line is a random angle, not parallel to the wall for which the dimension would be appropriate.
-JS
3 Replies 3
I know this is elementary, but ...
Eduardo Rolon
Set the rotation angle in Grid Options to 0 to see if it is the one causing the problem.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Yes. That seems to solve the problem. Thank you.
I had rotated an imported survey then rotated the grid and the dimensions were following the original grid orientation.
-JS
