Dimension to Center of Fix Window
Is there a way of dimensioning to center of a AC9 Fix Window Objects (there is no hot points in center of the window)?
Thanks,
Joseph
Hi Joseph,
I display window markers on my plans and dimension to the hotspot on the marker, which is at the centerline.
HTH,
Karl
Also, if you use automatic dimensioning, it will dimension to the center of the Fixed Window (Tools/Automatic Dimensioning/Exterior Dimensioning...)
