Dimension to Center of Fix Window
Is there a way of dimensioning to center of a AC9 Fix Window Objects (there is no hot points in center of the window)?
Thanks,
Joseph
Hi Joseph,
I display window markers on my plans and dimension to the hotspot on the marker, which is at the centerline.
HTH,
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Also, if you use automatic dimensioning, it will dimension to the center of the Fixed Window (Tools/Automatic Dimensioning/Exterior Dimensioning...)
