Zdenko
Dimensioning User Interface Greyed Out
something i noticed when attempting to move a dimension line and not sure i understand why one is greyed out and unable to move the dimension line.
Operating system used: Mac Intel-based Sonoma 14.5
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
1 Solution
Hi @Zdenko,
only one thing you should be aware of is when you select a dimension line you have to see the Mercedes arrow then select it (like in the first long dimension line).
But when the dimension line is short (as in the second case) you have to zoom in until you get that Mercedes arrow appears then select it.
AC 29 INT 4006/WIN 11
Go to post
6 Replies 6
runxel
One time you clicked on the main dimension line, the other time you clicked on a dimension node.
You may ask "why" and fair enough, but this is done so nodes can e.g. have different witness line styles.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Zdenko
will send video monday
Sequoia 15.1.1
Do not click on the dimension node or the exact centre point between dimension nodes, because that does not select the dimension line.
Click on the line itself or drag a selection box around the node/s on the end of the dimension line/s (or actually anywhere across the dimension line/s) to select it/them.
Zdenko
so this is what i was trying to convey concerning the inability to move the dimension line.
Sequoia 15.1.1
Hi @Zdenko,
@Mahmoud Qenawi wrote:
Hi @Zdenko,
Exactly, as I said in my post - "Do not click on the dimension node or the exact centre point between dimension nodes, because that does not select the dimension line."
