Display wall core only in AC11
Is there a way to dispaly the wall cores only in AC11? I am wanting to show the full wall composite in my 1:50 sections and show only the core structure in the 1:100 plans. I see there is the Partial Structure function in AC12 onwards.
Cheers
5 Replies 5
I am afraid it is not possible in v11.
We had to come up with various workarounds like modeling the core separately on a different layer or modeling the composite wall out of several walls.
Hi
Unfortunately not much help, but seems I did something with a pen set (or emulated core-only (and saved view) somehow), but still would have to draw closing line at window /doors if I remember right, its been a while.
Maybe someone else can help out here.
lec
Actually that may work.
You can create a Pen Set in which all skins and skin separator lines you don't want to see are displayed with a white pen.
Of course this is just a display thing but may give you the result you want.
Pen set approach:
http://archicad-talk.graphisoft.com/viewtopic.php?p=97839#97839
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks guys, will give the penset method a go. This is the first time I've attempted a full documentation set 'live' in Archicad, definately a bit to learn. The partial structure display looks like a very handy tool, I think a software upgrade is long over due
Cheers
