RobiLMan
Distance Guides - Door dimension middle marker
Hi, how can I change my default setting for door dimensions (distance from wall) to be set from middle and not from sites?
1 Solution
You can change the Distance Guides settings.
Although it may go to the centre of the door leaf rather than the centre of the overall frame.
I am not sure.
Go to post
4 Replies 4
I am not sure.
RobiLMan
Thanks, its working... Is there a way to have is set to middle for doors and edges for windows?
Patrick M
in general, it would be awesome if distance guides were more cognizant of every elements reference point/line. The one that gets me is things like plumbing fixtures. Toilets are 16-18" center to face of finish. But the distance guides only go to the edge of the toilet, which is a reference no one cares about.
in general, I still use the "move it, then move it again" method; its 100x faster than trying to get distance guides or even the tracker origin reset to work.
Not as far as I know.
You have to make the setting change yourself.
But you should be able to setup a keyboard shortcut for it in the Work Environment (I say this without having checked it myself).
